  3. where should allegro.ilinit reside
  • Views 17597
uamcap27
uamcap27 over 16 years ago
Im using v16.2 and I can't find the allegro.ilinit file.I am supposed to load my skill codes but I cant find that file.Where does this file located from?,I cannott find it under pcbenv.
  • DE202408202727
    DE202408202727 over 16 years ago
    Where does your ALLEGRO_SITE variable point to?
    Place your allegro.ilinit file (you probably need to create it) in the skill folder under there. You may need to create that too.
  • uamcap27
    thanks for the info dave.I copied example.ilinit file under <cdsroot>/share/local/pcb/skill to <HOME>/pcbenv and named it allegro.ilinit.
  • rinj
    rinj over 15 years ago
     Hi all,
    I have the skill code, that creates a file with pick and place data that can be backannotated into Capture/Capture CIS
     pickdata settingSettings done:C:\Cadence\home\pcbenv\allegro.ilinit!!C:\Cadence\home\skill\pickdata.il file & its .il.bak file. System variable path: HOME   C\Cadence\home After restarted the tool, To run the program I typed,  Command > pickdata on the Allegro; command line.
    But the message is: Command not found.
    The same settings I did in another system (I think so) & the same file worked.
    Can anybody help me, what's arong with my settings now.
     rinj
  • DE202408202727
    DE202408202727 over 15 years ago
    Typing "pickdata" on the command line will only work if "pickdata" is registered as a command in your allegro.ilinit file.
