  3. Remove BackSlash on a string
  • Subscribers 163
  • Views 15162
archive over 16 years ago
Hi Guys
I am stuck on this issue for a while now basically this is want I want to do
 I want to write a string to a text file but without the quotes, so I use stringToSymbol
but the problem is when ever a string starts with a number rather than alphabets the function adds a backslash to the numbers
for example
str = "0201AAA"
concat(str) => gives out \0\2\0\1AAA as the answer
This s**ks because all I want was just 0201AAA
but if str = "A0201AAA"
concat(str) would give A0201AAA without the quotes perfect
My intention is to use this value in an fprintf statement so that the "quotes" are not printed on the file
Please help me
regards
Venkata
  • Randy R
    Randy R over 16 years ago
    Instead of turning it into a symbol, see if this works for you.  My output file looks good (no backslashes).
     fprintf(outport "%s" str)
