  3. Text Editor
  • Replies 7
  • Subscribers 159
  • Views 14499
Text Editor
Khurana
Khurana over 15 years ago
What text editor do you use for writing skill code on windows?
Varun
  • eDave
    eDave over 15 years ago
    UltraEdit is good.
  • EvanShultz
    EvanShultz over 15 years ago
     I use Notepad++.
  • Khurana
    I am using Notepad++ as well since it helps ensuring that correct number of closed parenthesis are used.  Not sure if UltraEdit has that capability.  I was wondering if there's a text editor out there that recognizes Skill keywords, and as such highlights (the keywords) for easy readability.
  • natebizu
    natebizu over 15 years ago
    UltraEdit can do syntax highlight, brace match, list procedures in a open file and, with a c-tag config file, can find all the procedures(and defun) in a project that will allow you to jump to a procedure in any file by putting the cursor on a procedure name and hitting the F12 key.
    archive over 15 years ago
    Hi Nate
    Can you share the c-tag config file and info on how to set it up?
    regards
    Venkata
