  3. create symbol with skill
  • Replies 9
  • Subscribers 167
  • Views 22456
Ejlersen
Ejlersen over 16 years ago
Hi
I have a text file with coordinates for a number of shape symbols that I need to create. My problem is how I inside skill can create a new .dra file and then draw the shape and save the .dra/ssm file.
I've look at numerous axl functions without getting something to work - does anyone have an idea?
I could probably create scripts to generate new shape symbols and save them using scripts, but I would rather avoid using scripts.
Best regards
Ole
  • Ejlersen
    Hi Dave
    Thats weird, since the code does contain "axlSaveDesign(?noMru t)" so that should be fine, but only the .dra file is saved, no ssm.
    Maybe its because I only run the defun and not the complete skill program?
    Best regards
    Ole
  • Yann00
    Yann00 over 13 years ago
    hi Dave and Ejlersen,
    Did you solve your problem?
    Because I want to create file.osm associated to my .dra file. And axlSaveDesign does only create my .dra file.
    Have you got any solution for that? Thanks
  • djhutchi
    djhutchi over 13 years ago
    Try using axlCompileSymbol
    axlCompileSymbol(
        [?symbol t_name]
        [?type t_type]
        [?silent t/nil]
        [?silentOnOverwrite t/nil]
  • Yann00
    Thanks a lot, it works.
    Just an information: You have to do that after axlSaveDesign of your file.dra
    Otherwise it does not compile the symbol.osm
