  3. create symbol with skill
  • Replies 9
  • Subscribers 167
  • Views 22455
Ejlersen
Ejlersen over 16 years ago
Hi
I have a text file with coordinates for a number of shape symbols that I need to create. My problem is how I inside skill can create a new .dra file and then draw the shape and save the .dra/ssm file.
I've look at numerous axl functions without getting something to work - does anyone have an idea?
I could probably create scripts to generate new shape symbols and save them using scripts, but I would rather avoid using scripts.
Best regards
Ole
  • aCraig
    aCraig over 16 years ago
    Hi Ole,
    Have you tried  "axlDBCreateSymDefSkeleton"? I've use this to create new symbols in a design.
    -Craig
  • DE202408202727
    DE202408202727 over 16 years ago
    Hi Ole,
    If I understand your problem correctly you want to create a symbol without leaving your current design session?
    I can't think of a non-script way to do that but I get around the problem with a series of tricks to save my current design, open the symbol editor, create my symbol and re-open the original design:
        draName = "myDra"
        currentDesign = axlCurrentDesign()
        state = axlSaveEnable()
        tempDesignName = "temp.brd"
        axlSaveDesign(?design tempDesignName, ?mode "nocheck", ?noMru t)
        AFn_OpenDesign(?design strcat(draName, ".dra"), ?mode "wf", ?noMru t, ?noConfirm t, ?forceNew t)
        axlSetSymbolType("shape")
        AFn_OpenDesign(?design tempDesignName, ?mode "wf", ?noMru t, ?noConfirm t)
        axlSaveDesign(?noMru t)
        axlRenameDesign(currentDesign)
        deleteFile(tempDesignName)
        axlSaveEnable(state)
    defun( AFn_OpenDesign (@key design, (mode "w"), noMru, noConfirm, forceNew)
     let((noconfirmStatus, result)
      when(noConfirm, noconfirmStatus = axlGetVariable("NOCONFIRM"), axlSetVariable("NOCONFIRM", t))
      when(forceNew && isFile(design), deleteFile(design))
      result = if(noMru && axlVersion('version) >= 16.0
       then axlOpenDesign(?design design, ?mode mode, ?noMru t)
       else axlOpenDesign(?design design, ?mode mode)
      when(noConfirm, if(noconfirmStatus then axlSetVariable("NOCONFIRM", t) else axlUnsetVariable("NOCONFIRM")))
      result
    Dave
  • Ejlersen
    Hi Dave
    Thanks for the tip, I'll try it out.
    Best regards
    Ole
  • Ejlersen
    Hi Dave
    This seems to work fine, a small correction
    you need to run axlSaveDesign before AFn_OpenDesign in the end to save of the symbol
    I was wondering if you have a method to write the symbol file also, I can only get it to save the .dra file
    Best regards
    Ole
  • DE202408202727
    Hi Ole,
    axlSaveDesign should also create the compile the symbol if you are in the drawing editor.
    Dave
