  3. PCB Template Comparision from allegro
  • Subscribers 166
  • Views 14587
Chinnu123
Chinnu123 over 16 years ago
Is it possible to compare the 2 templates (Board file Data) using third part tool like Excel...
is there any way to extract the complete information from allegro for the template which includes all the components and text.
Does any one have an idea on this really helpful to me?please share
  • Khurana
    Khurana over 16 years ago
    Yes, you can export "complete" information from Allegro - use the attached file as input to the extract routine and you will get the ascii version of the brd.
    • db.txt
  • Chinnu123
    Thanks Khurana for sharing this information,I am able to export to ASCII format using  allegro command "Extracta" but exporting seperately get board stackup one time,get board outline one time,get board traces,vias,pins one time.here i have to run the "Extracta" command 3 times.is it possible to run entire components in single time, i have already tried but Extracta was not extract might be i have  choosen wrong method. can you help me how to extract entire components data in sigle attempt to ASCII format using Extracta command.
