  3. Update Text variables across all layers instantly
  • Views 15020
Robyd
Robyd over 16 years ago
Hello
I am looking for a functionality i used in old P-cad (windows Version)
It allowed you to instantly update all kind of text variables that change from design to design
There was a form with all variables which you could fill at final stages
and you could reflect all those values all over the design where the variables are located
Variables were in different layers with different text size and justifications.
This way you save time updating different values in different layers and avoiding miss of few
And increase automation and confidence that all updates to Manufacturing notes and master drawing done.
Possible variables are:
Date
customer name
design name
PCB P/N & Rev
Assy P/N
layout designer name
PCB finish
layer count
pad count
Copper Thicknesses
 etc...
With this functionallity you could prepare PCB templates containing all variables in place
And possibility to update all changes from one unified form at end of design
Is there any way to implemet this?
Do you think it is necessary ?
Thank you
Robyd
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    Yes this can be done. I have a titleblock update program that needs to be cleared for custom data before I can publish it.
    However, until then you can use the attached skill program, which search and replace after a string starting with "Date:" and fills out the current date and time
    It can easily be expanded to look for other names, or just specific subclasses etc.
    Best regards
    Ole
    ns_date.il
    archive over 16 years ago
    Check out this utility I wrote http://www.cadence.com/Community/forums/p/14379/24289.aspx#24289 regards Vramanan
