  3. Highlight Objects
  • Views 15475
Highlight Objects
aeris
aeris over 16 years ago
I'm using the axlUIViewFileCreate to show data in Allegro, anyone tried zooming and highligting objects using the output report, the current output report by this function only allow user to zoom in at specific locations but no hilighting done
-- the report is in HTML format via Setup >> User Preference >> UI >> Enable HTML
thanks
  • fxffxf
    fxffxf over 16 years ago
    It currently only supports zoom center to coordinates
  • aeris
    Thanks fxffxf, guess we'll just have to create a substitute form with grid where we can add Highlighting of objects events.
    A follow up question is. Is there a way to add/catch the close event of the Report Form
    thanks
  • fxffxf
     this is not supported.
  • Helen
    Helen over 15 years ago
    When capturing objects xy next statement should be
    axlHighlightObject()
    You will have all objects highlighted and then zoom using report.
