  3. ExtractToFile
  • Replies 7
  • Subscribers 166
  • Views 17868
ExtractToFile
LP2R4T
LP2R4T over 15 years ago
 Can Anyone tell me Where can I find the list of items that can be part of the extract command file for the axlExtractToFile function?
 Thanks in advance,
  • DE202408202727
    DE202408202727 over 15 years ago
    Look for algrodesrls.pdf in the ...\doc\algrodesrls folder.
  • LP2R4T
    Thanks Dave,
    I tried the following with no success. Do you know why?
    procedure( doExtracts()
    let( (extPortdata)
    extPortdata=outfile("Component.txt")
    fprintf( extPortdata "COMPONENT\n")
    fprintf( extPortdata "REFDES\n")
    fprintf( extPortdata "END\n")
    close( extPortdata)
    axlExtractToFile( "Component.txt" "Comp.refdes" "quiet")
    )) ; end doExtracts
  • djhutchi
    djhutchi over 15 years ago
    It works correctly for me…
    P:\training>allegro -safe return_path6_163.brd
    P:\training>type allegro.jrl
    \t (00:00:08) allegro 16.3 S021 (v16-3-85BG) i86
    \t (00:00:08)
    \t (00:00:11) Opening existing drawing...
    \d (00:00:11) Database opened: P:/training/return_path6_163.brd
    \i (00:00:12) trapsize 878
    \i (00:00:12) generaledit
    \i (00:00:24) skill 'load "test.il"'
       (00:00:24) t
    \i (00:00:30) skill doExtracts
       (00:00:30) t
    \i (00:00:32) exit
    P:\training>type test.il
        let( (extPortdata)
            close( extPortdata)
    ) ; end doExtracts
    P:\training>type Comp.refdes
    A!REFDES!
    J!P:/training/return_path6_163.brd!Tue Dec 14 07:52:25 2010!-3500.00!-500.00!13500.00!10500.00!0.01!mils!RETURN_PATH!63.200000 mil!6!OUT OF DATE!
    S!J9G1!
    S!P9K1!
    S!J1H1!
    S!J3H1!
    S!P1K1!
    S!P3K1!
    S!P5K1!
    S!P4K1!
    S!J4H1!
    S!J5H1!
    S!JT8F1!
    S!JT8B1!
    S!JT2B1!
    S!JT2F1!
    P:\training>
  • DE202408202727
    That code should work. I loaded the procedure and ran it using doExtracts()
    Here are the first few lines of the file it produced for me:
    A!REFDES!
    J!K:/220_02114/02B/worklib/physical/220-02114-02A.brd!Wed Dec 15 08:01:13 2010!-100.000!-120.234!863.600!558.800!0.001!millimeters!220_02114!62992.125984 mil!10!OUT OF DATE!
    S!U301!
    S!U302!
    S!D1101!
    S!D1102!
    S!D1103!
  • marcusj
    marcusj over 15 years ago
    What release are you using? You should see a filename: algrodescmp.pdf in your documents folder. It contains the Extract Dictionary of all of the views that can be used to extract data from an Allegro database.
    <CDS_INST_DIR>\doc\algrodescmp\algrodescmp.pdf
    Marcus Johnson
    marcusj@cadence.com
