  3. SKILL to Create 'Allegro Design Entry CIS' symbols and ...
  • Views 8758
SKILL to Create 'Allegro Design Entry CIS' symbols and 'Allegro PCB Editor' footprints
seddona
seddona over 15 years ago
Hi, I believe it is possible to programmatically create Allegro PCB Editor footprints using SKILL but I was wondering if you can use SKILL in Allegro Design Entry CIS or if there is another way to programmatically create schematic symbols? Thanks, Andrew
  • seddona
    For anybody that is interested, it appears the latest hotfix allows scripting with TCL.
  • seddona
    Can anybody point me to some example SKILL for creating footprints in Allegro PCB? Or at least the documentation describing the footprint model. Thanks
  • DE202408202727
    DE202408202727 over 15 years ago
    Here is some very basic example code. You need to be in the symbol editor to create parts. Just open a new DRA.
    Note that this code requires units to be set to mils for the benefit of US readers. However, I don't encourage developing libraries in units other than mm.
    You will need to substitute the padname "255C" with one from your library to test the code.
    Dave
    defun( exampleSymbol ()
     let((layer, placeBound, padName, txtOrient, txtLoc)
     ; Assembly top outline:
     layer = "PACKAGE GEOMETRY/ASSEMBLY_TOP"
     axlDBCreateRectangle(list(-100:-200, 100:200), nil, layer)
     ; Place Bound Top:
     layer = "PACKAGE GEOMETRY/PLACE_BOUND_TOP"
     placeBound = car(axlDBCreateRectangle(list(-100:-200, 100:200), t, layer))
     when(placeBound, axlDBAddProp(placeBound, list("PACKAGE_HEIGHT_MAX", 40)))
     ;Silkscreen outline
     layer = "PACKAGE GEOMETRY/SILKSCREEN_TOP"
     axlDBCreateLine(list(-110:-210, -110:210, 110:210, 110:-210, -110:-210), 8.0, layer)
     ; Pins:
     padName = "255C"; ********* Substitute your own padstackname here if testing this code ************
     when(axlLoadPadstack(padName)
      example_makePin(padName, 0:-150, "1", ?txtBlk "1")
      example_makePin(padName, 0:150, "2", ?txtBlk "1")
     ;Silkscreen designator
     layer = "REF DES/SILKSCREEN_TOP"
     txtOrient = make_axlTextOrientation(?textBlock "2", ?justify "center")
     axlDBCreateText("XXXXX", 0:250, txtOrient, layer)
     ;Assembly reference designator
     layer = "REF DES/ASSEMBLY_TOP"
     txtOrient = make_axlTextOrientation(?textBlock "1", ?justify "center")
     txtLoc = 0.0:axlGetParam("paramTextBlock:1") ->height / -2.0
     axlDBCreateText("XXXXX", txtLoc, txtOrient, layer)
    defun( example_makePin (padStackName, loc, pinNumber @key (txtBlk "1"))
     let((txtO, txtOffset, txtid)
     txtOffset = 0.0:axlGetParam(strcat("paramTextBlock:", txtBlk)) ->height / -2.0
     txtO = make_axlTextOrientation(?textBlock txtBlk, ?justify "center")
     txtid = make_axlPinText(?number pinNumber,?offset txtOffset, ?text txtO)
     axlDBCreatePin(padStackName, loc, txtid)
