  3. Limit Form field data entry
  • Views 14811
LP2R4T
LP2R4T over 15 years ago
Hello.
I want to limit form field data entry to numerical values(no minus values) but I am able to have minus signs entered The form field is a STRFILLIN
here is what I have used:
(case VCF->curField
  ("space_1_x_spaces"
   unless(forall(nStr, parseString(VCF ->curValue), rexMatchp("^[-]*[0-9]*[.]*[0-9][0-9]$", nStr))
    axlFormRestoreField(VCF, VCF ->curField)
 I though that the ^ was a negation.
Thanks in Advance
  • DE202408202727
    DE202408202727 over 15 years ago
    There are many ways you could do this - but why not use a real number form field in the first place and set the lower limit to 0?
    If you really must accept a string then a valid test (for a positive real number) might be:
    rexMatchp("^[0-9]+[.][0-9]+$", VCF ->curField)
    The "^" character at the beginning matches the start of the string - the "$" matches the end.
    Dave
  • LP2R4T
    Thanks Dave,
    I am using a STRFILLIN because I want the users to be able to enter many real numbers at once in the same field.
    I would like it to be limited exactly the same as the grid spacing Set up menu in APD
    -  Multiple real numbers in the same field.
    - Only positive real number
    - With or without decimals.
    Can I use a logical operator with the rexMatchp to have more then one match possible?
  • LP2R4T
    Dave,
    Here is what I have used "^[0-9]*[.]*[0-9]*$"
    It does what I need.
