  3. ExtractToFile
  • Views 14156
ExtractToFile
LP2R4T
LP2R4T over 15 years ago
Here is a simple program that doesn't work when I am adding the 2 lines that are in comments below. I would like to specify which class and subclass I want the data from.
Do you know why?
procedure( doExtracts()
let( (extPortdata)
extPortdata=outfile("Component.txt")
  fprintf( extPortdata "GEOMETRY\n")
 fprintf( extPortdata "CLASS = COMPONENT GEOMETRY\n")
 fprintf( extPortdata "SUBCLASS = ASSEMBLY_BOTTOM\n")
 fprintf( extPortdata "GRAPHIC_DATA_3\n") ; width
 fprintf( extPortdata "GRAPHIC_DATA_4\n") ; height
 fprintf( extPortdata "END\n")
close( extPortdata)
axlExtractToFile( "Component.txt" "Comp.refdes" "quiet")
)) ; end doExtracts
doExtracts()
  • djhutchi
    djhutchi over 15 years ago
    There is no class “COMPONENT GEOMETRY”, I think you need to be using “PACKAGE GEOMETRY” instead
  • fxffxf
    fxffxf over 15 years ago
    Try using  PCB CLASS names not APD names (e.g. "PACKAGE GEOMETRY") or
        axlMapClassName("COMPONENT GEOMETRY" t)
