  3. Skill Script to update widths in a constraint region
  • Subscribers 166
  • Views 14834
pdxg8r
pdxg8r over 15 years ago
Hi All,
 I was hoping one of you could help me out. I have a BGA with a constraint region around the boundary. I have the widths within the constraint region defined in constraint manager through a Physical Constraint Set. Unfortunately, the widths/differential spacings within the region have changed and now i have thousands of LW DRCs within the region.
I was wondering if anyone had a simple script that would update all the line widths within the region to their given widths within the PCSet?
Thanks in advance!
  • Khurana
    Khurana over 15 years ago
     Attached Skill script is not written for regions, but may still be of some use to you.
    cwidth.il
  • Ark angel
    Ark angel over 15 years ago
    wow that is really hard, perhaps by changing the CM and update the layout, they automatictly change the pattern into your standard, perhaps it could be help
