  3. how to get error response from axlShell
  • Views 14598
Ejlersen
Ejlersen over 15 years ago
Hi
I need to run a command using axlShell, but no matter what command I run the result is true and not the error code
return=axlShell("garbage")
Skill > ret=axlShell("garbage")
E- Command not found: garbage
t
Now the value of return is t since the command executed, but I would like to know the "E" part which tells that the command did not succeed.
Any ideas? My own suggestion is to write a script and do the same, that should produce an error.
Best regards
Ole
  • Ejlersen
    just found out that using a script is not a solution
    Ole
  • aeris
    aeris over 15 years ago
    maybe not the typical "skill" solution...
    1. check if the file to be executed is a valid file -- skip module if not
    2. if its a valid application, check/read for the log file of the app after running axlShell
    aeris
