  3. Net Class Class API's
  • Replies 8
  • Views 5336
aeris
aeris over 15 years ago
Please help on the following
  1. How to create Net Class-Class Objects
  2. How to get NCC children from the available Spacing CSet
  3. Assign a particular Spacing CSet to each NCC Child
I tried looking from the skill document but i only found axlCnsDeleteClassClassObjects()
thank you
  • fxffxf
    fxffxf over 15 years ago
    You will need 16.5 whenever it released...
     - How to create Net Class-Class Objects
          axlCnsClassTableCreate
    -  How to get NCC children from the available Spacing CSet
          You would need to fetch all entries by using axlCnsClassTableFind('netclass) and then do an additional search on the returned list to find which entries that match the cset of interest.
    -  Assign a particular Spacing CSet to each NCC Child
         Assign while creating object via axlCnsClassTableCreateor change assignment by axlCNSClassTableChange
  • aeris
    thanks, but for now, I'm limited to v16.2
  • PCB George
    PCB George over 15 years ago
     OK, Frank, you did it now :)
    When can weexpect 16.5 to be released?
  • DE202408202727
    DE202408202727 over 15 years ago
    Mid-May is what's stated in the release schedule.
  • aeris
    So for Allegro v16.2 users, the only way is to do it via Script?
     thanks for the heads up for the upcoming API updates
