  3. PCB: Properties attached to a component instance
  • Subscribers 166
  • Views 19151
Thierry22
Thierry22 over 15 years ago
 In my Allegro PCB I have a property attached to the component instance, and I would like to extract it using a skill script but how ?
Is there any body having this issue?
 Thanks for your help
 Thierry
  • Khurana
    Khurana over 15 years ago
    Let me see if I can get the pseudocode right:
    - obtain the design dbid
    - obtain list of components
    - obtain component definition (compdef) for each component
    - obtain the propList for each comp_def
    - loop thru each prop in the propList
  • DE202408202727
    DE202408202727 over 15 years ago
    Here's a small routine I have to display a data sheet based on the component part number property. I hope it adequately demonstrates how to obtain component properties:
    defun( ShowCompDataSheets ()
     let((dataShtsPath, popup, partNumber, pdfFile)
      dataShtsPath = "XXXXXXXXXX/DATASHEETS/"
      popup = axlUIPopupDefine(nil, list(list("Done", 'axlFinishEnterFun), list("Cancel", 'axlCancelEnterFun)))
      axlUIPopupSet(popup)
      axlSetFindFilter( ?enabled list( "NOALL" "COMPONENTS" "NAMEFORM") ?onButtons "COMPONENTS")
      while(axlSelect()
        partNumber = get(car(axlGetSelSet()) ->compdef ->prop, "PART_NUMBER")
        if(partNumber then
          pdfFile = strcat(dataShtsPath, partNumber, ".pdf")
          if(isFile(pdfFile) then axlPdfView(pdfFile) else axlUIConfirm("No pdf data sheet exists for this component"))
         else
          axlUIConfirm("This component has no part number as required to locate a datasheet")
      axlUIPopupSet(nil)
  • GraF
    GraF over 15 years ago
    Hi eDave, your routine can solve a problem that I've into my dept but I need your help to obtain a "customized" version.
    I need to know the string contains into the key-property "VALUE" of the components (which is passed by a PTF file when the compnonets are added to the schematic) when I'm using APD.
    I've tried (unsuccesfully) using the existing skill code "dsht.il" with some little modifications.
    I've realized that (perhaps) there's a different "compdef" related to key-properties which must be used to get values, but my understanding aren't so big..
    Many thanks in advance
  • DE202408202727
    I think that there is probably a difference here between Allegro PCB and APD. I don't have APD so can't really help you. Maybe someone else can.
    Dave
  • Pradeep Appu
    Pradeep Appu over 7 years ago in reply to DE202408202727
    Hi eDave,
    I've tried using the existing skill code "dsht.il" with some little modifications. allegro 17.2
    "search = strcat("">www.google.com/search, value)
    axlHttp(google_search)" this function not working
    axlCmdRegister( "show_datasheet" 'ShowCompDataSheets)
    let((dataShtsPath, popup, value, pdfFile,search)
    dataShtsPath = "C:/Users/Pradeep/Desktop/test/DATASHEETS/"
    while(axlSelect()
    value = get(car(axlGetSelSet()) ->compdef ->prop, "PART_NUMBER")
    if(value then
    pdfFile = strcat(dataShtsPath, value, ".pdf")
    else
    axlHttp(search)
    else
    axlUIConfirm("No part number as required to locate a datasheet")
    axlUIPopupSet(nil)
    Pradeep
