  3. "Header" files in skill and limits in dll files (fxffxf...
  • Views 2605
"Header" files in skill and limits in dll files (fxffxf 4 U maybe :-)).
Romme
Romme over 15 years ago
Hello everyone.
  On doing some skill jobs again and again and ... One might find it smart to do an "external" skill job with the repeated parts. And no problem here. But as in Assembler, Pascal and C one could put variables into a header file. Is it possible to make a blabla.il file without any functions or procedures, but only variable declarations ? Eg if one are using a modified code from Dave to do footprints it could be easy to place line width and such in the "header" file to have all footprints looking equal. something like :
Assy_Lines = 0.05
Silk_Lines  = 0.15
Assy_pin1_Mark_IC = Circle
Silk_pin1_Mark_IC  = Circle
Assy_pin1_Mark = 1
Silk_pin1_Mark  = 1
This little short examble is to short to show the advantage of a header file, but i hope You do understand :-).
Additionally. Is there some where a good (not the one from the home path) explanation on how to do a dll files with skills and explaning the limits in programming this way ? Eg when looking at the exambles it looks like demands are one way only, understood as You can call functions and procedures in the dll file, but from this dll file you cannot control anything Allegro ? Am i wrong ?
Rgds
  Klavs.
  • DE202408202727
    DE202408202727 over 15 years ago
    You can declare such global variables in your allegro.ilinit file. For instance I have the following variable declared:
    defvar(taitCurrentAllegroVersion, 16.3)
  • EvanShultz
    EvanShultz over 7 years ago in reply to DE202408202727
    Hi all,
    Resurrecting a very old thread...
    If you do this sklint will complain about it. I can find on the forum there is a way to ignore variable prefixes but I didn't see the syntax. To hopefully save somebody else time in the future, here is how to avoid Lint issues with the global variable defined above using a generic file name:
    sklint(?file "skill.il" ?prefixes list('tait))
  • DE202408202727
    DE202408202727 over 7 years ago in reply to EvanShultz
    Thanks Evan. I wasn't aware of this. I have taken to including a dummy function within my utilities where I declare such variables to avoid such lint complaints. Now I have a good alternative.
