  3. Insert wait time
  • Replies 13
  • Views 22062
Insert wait time
Ejlersen
Ejlersen over 15 years ago
Hi
Does anyone know of a way to insert a waiting time in skill?
sometimes it seems like the skill code proceeds even though e.g. axlShell or runBatchFile commands are not finished.
Best regards
Ole
  • vramananx
    vramananx over 15 years ago
    removed bec of formatting issue
  • vramananx
    Hi Guys
    Its strange I was wondering about the same issue for the last couple of days
    Ideally I am running a batch program from my skill (updating all the dra files) then refresh the symbols inside the design
    but that doesn't work the way I imagined, allegro just keeps refreshing the symbols long before I modify the symbols
    so I thought about a scheme why not
    1. set a system variable using setx before calling the batch file
    system("setx timer=0")
    2. then call the batch file, the batch file has a for loop and it launches the allegro for all the dra files in the directory
    3. at the end of the batch set the timer1 to 1
    in skill launch a loop to check for timer value 1 and get out (the end of batch would trigger this)
    but my diabolical scheme didn't work since I am stuck at this point
    setx works fine and i can see the variable in my user environment
    but when i immediately try to check using  getShellEnvVar("timer") the results are nil
    it looks like allegro has to be relaunched to be able to read the system variable
    I would appreciate any comments on this or how to set and read the environment variable in the same session
    regards
    Venkata
  • fxffxf
    fxffxf over 15 years ago
    If putting a UI based program in a bat file sometimes you need to use the cmd.exe "start" command to have the bat file wait for the UI program to finish. For example, if you want to run allegro from a bat file you would need:
      start /wait allegro
     See http://ss64.com/nt/start.html
    The problem you have with setx is that it only effects new programs not existing programs. Allegro does not dynamically update itself based upon changes to system environment variables that might be changed by its spawned children. Allegro reads the system environment variables only at startup.
  • vramananx
    Hi fxffxf
    I do use the /wait
    the problem is I call the batch file from a master design now the skill calls the batch and goes on to execute the next commands
    the skill would execute the refresh symbols long before all the dra batch edits are done
    regards
  • fxffxf
    You should file a query with Cadence and include a simple testcase because I don't see this happening. I use the Skill system command to run a bat file which runs allegro.exe
