  3. Insert wait time
  • Replies 13
  • Views 22068
Insert wait time
Ejlersen
Ejlersen over 15 years ago
Hi
Does anyone know of a way to insert a waiting time in skill?
sometimes it seems like the skill code proceeds even though e.g. axlShell or runBatchFile commands are not finished.
Best regards
Ole
  • Ejlersen
    Hi
    Along the same lines, I'm having a skill program call another skill program (with its own gui)
    The problem I'm seeing is that the calling skill program continues and does not wait for me to finished the other skill program.
    What would the solution to this be?
     Ole
  • fxffxf
    fxffxf over 15 years ago
    The GUI skill program will either need to have its form be blocking or insert a dummy axlEnterEvent loop (see in cdsroot the example file cns-design.il). Either method will prevent the other GUI code from returning to the calling skill program until the user has finished with it.
  • vramananx
    vramananx over 15 years ago
    Guys
    In my company they have some internal functions that would do what we want
    I can't give the code but I can say that they use the IPC functionality
    basically you write a function to pass the command line/batch file as an argument to a IPC process and wait for the return value
     best of luck
    regards
    venkata
