  3. "File Open" and "Save As" in SKILL
  • Replies 7
  • Subscribers 163
  • Views 8818
Orit
Orit over 15 years ago
Is there a way to use SKILL code to implement an input file selector and a output file selector, similar to Windows Notepad, in a SKILL generated form?  I can do the form, but could not find any mention of a file input/output dialog API.
I'd appreciate any hint on this.
  • fxffxf
    fxffxf over 15 years ago
     have you looked at axlDMFileBrowse
  • Orit
    If I am not mistaken, axlDMFileBrowse is just a file open command with some Allegro environment decorations. The axlDMFxx functions do not open a GUI dialog to select the desired file.
  • fxffxf
    Try typig on allegro cmd line: skill axlDMFileBrowse("ALLEGRO_TEXT" nil)
    and you should see the result below. Is the what you want?
  • Orit
    Thanks for the suggestion. I will try it and report back.
    BTW, you wrote "you should see the result below" - I don't see any picture or attachment in your post.
  • Orit
     Great. It appears to do what I wanted.
    I appreciate the help.
