  3. How to Extract Through Holes and Slots Seperately
  • Replies 9
  • Views 20199
ahood
ahood over 15 years ago
Hi
I am trying to extract a seperate count for Through Holes with Hole Type set as: Circle_Drill as opposed to those set as: Oval_Slot or Rectangle_Slot. Can anyone assist as I am not sure what the command to pull the Hole Type out is?
 Below is a section from my skill script that just selects all Through Hole Pads
 foreach(pin pins_list
 if(pin->isThrough == t then
  pin_xy = pin->xy
  padstack = car(pin->pads)->parent
  drill = padstack->drillDiameter
  pin_name = padstack->name
  plating = axlDBGetDrillPlating(pin_name)
  if(drill > 0 then
   if(rexMatchp("NON PLATED" plating) == nil then
    if(member(drill pdrill_list) == nil then
     pdrill_list = cons(drill pdrill_list)
   else
    if(member(drill npdrill_list) == nil then
     npdrill_list = cons(drill npdrill_list)
   pin_count++
Regards
ahood
  • DE202408202727
    DE202408202727 over 15 years ago
    In 16.5 these attributes of the padstack are available as drillSizeHeight and drillSizeWidth. Otherwise you will need to use drillFigureHeight and drillFigureWidth or extracta as you suggest.
  • ahood
    Hi Dave
    Thanks for the help.
    I will take a look at using the new padstack attributes to pull this information when I start using 16.5.
    Regards
    ahood
  • ahood
    Hi Nagaraj
     Thanks for the information, I will try this out and see if I can get it to work
     Regards
     ahood
  • tingletingle
    tingletingle over 15 years ago
    Hi Dave
    It will return nil if Allegro version is 15.7.
    I use system(strcat("report -v pad " brdFile reportFile) to export padstack info.
