  3. How to Extract Through Holes and Slots Seperately
  • Replies 9
  • Views 20197
ahood
ahood over 15 years ago
Hi
I am trying to extract a seperate count for Through Holes with Hole Type set as: Circle_Drill as opposed to those set as: Oval_Slot or Rectangle_Slot. Can anyone assist as I am not sure what the command to pull the Hole Type out is?
 Below is a section from my skill script that just selects all Through Hole Pads
 foreach(pin pins_list
 if(pin->isThrough == t then
  pin_xy = pin->xy
  padstack = car(pin->pads)->parent
  drill = padstack->drillDiameter
  pin_name = padstack->name
  plating = axlDBGetDrillPlating(pin_name)
  if(drill > 0 then
   if(rexMatchp("NON PLATED" plating) == nil then
    if(member(drill pdrill_list) == nil then
     pdrill_list = cons(drill pdrill_list)
   else
    if(member(drill npdrill_list) == nil then
     npdrill_list = cons(drill npdrill_list)
   pin_count++
Regards
ahood
  • DE202408202727
    DE202408202727 over 15 years ago
    Try using: pin->definition ->holeType
  • ahood
    Hi Dave
    Thanks for the quick response, I tried something similar, but am not sure of the correct  "holeType" entry,
    neither of these below appear to work
    if(pin->isThrough == t && pin->definition->holeType->circle_drill == t then
     or
    if(pin->isThrough == t && pin->definition->holeType == circle_drill then
    Regards
    ahood
  • Nagaraj Shanmu
    Nagaraj Shanmu over 15 years ago
    I did  a similar code for extracting the padstack info and below is the part of the code which u use for extracting the padstack and drill info
    axlPurgePadstacks('padstacks nil)
                axlPurgePadstacks('via nil)
                axlSetFindFilter(?enabled list("noall" "pins") ?onButtons list("noall" "pins"))
                pin_dbids = axlGetSelSet(axlAddSelectAll())
                axlClearSelSet(); clear all selection
                throu_pin_dbids = smd_pin_dbids =  list()
                foreach(pin_dbid pin_dbids
                if(pin_dbid->isThrough
                then
                throu_pin_dbids = cons(pin_dbid throu_pin_dbids)
                else
                smd_pin_dbids = cons(pin_dbid smd_pin_dbids)
                ); end for each pin type
    drilloutfile = outfile("drillchart.txt" "a")
    foreach(throu_pin_dbid throu_pin_dbids
                throu_pad_name = throu_pin_dbid->definition->name
                drill_size = throu_pin_dbid->definition->drillDiameter
                drill_type = throu_pin_dbid->definition->holeType
                plating = axlDBGetDrillPlating(throu_pad_name)
                drillFigureHeight = throu_pin_dbid->definition->drillFigureHeight
                drill_char = throu_pin_dbid->definition->drillChar
                drillFigureWidth = throu_pin_dbid->definition->drillFigureWidth
    drillFigureName = throu_pin_dbid->definition->drillFigureName
    fprintf(drilloutfile "%L,%L,%L,%L,%L,%L,%L,%L\n" throu_pad_name drill_size drill_type plating drillFigureHeight drill_char drillFigureWidth drillFigureName)
    ); end for each padstack information
    This throu_pin_dbid->definition->holeType  works for me to get the hole type.
    Good luck.
    Nagaraj.
  • DE202408202727
    if(pin->isThrough && pin->definition->holeType == "circle_drill" then
  • ahood
    Hi Dave
    Great that works fine, my other issue is accessing the Slot Length amd Width dimensions
    Using the Extracta command they are: DRILL_HOLE_NAME (major dim) & DRILL_HOLE_NAME2 (minor dim).
    Is it possible to pull this information as I am doing using the Drill Diameter in a similar way, see below?
    padstack->drillDiameter, this gives the drill hole diameter. If I use this command on a slot, the slot width is used.
    The command padstack->drillHoleName I presume accesses the DRILL_HOLE_NAME2 field for all types of hole.
    Can you assist further?
    ahood
