  3. How to make a dynamic right popup on a form treeview?
  • Views 14329
stillfish
stillfish over 15 years ago
I am trying to use the treeview item of the form.
Is it possible to have different right popup lists apply on different selected treeview items?
I have ever tried the function of axlFormBuildPopup().
But, the problem is I can only catch the form event "rightpopup" rather than "rightpopupPre" in the form callback,
And therefore, axlFormBuildPopup() cannot be called before the form item showing it's popup list.
Is ther any solution?
  • stillfish
    I found that when i right click on treeview item, callback return a "normal" event before i select from right popup list.
    And I change my callback like following to make it work.
    newPopup = list( list("option 1" "1") list("option 2" "2"))
    define(myFormCallBackAct (myform)
      case(myform->field
        ("myTreeview"
            case(myform->event
              ('normal
                 if(ChangePopup(myform->curValue) axlFormBuildPopup(myform "myTreeview" newPopup))
