  3. How to make a form and callback function working like axlUIPrompt...
  • Views 15651
How to make a form and callback function working like axlUIPrompt()
stillfish
stillfish over 15 years ago
Did anyone know how to build function with form like axlUIPrompt()?
I mean how to "stop" skill to run next statement until user press button on the form.
And how to get the return value from user's action since callback function is isolated function.
  • DE202408202727
    DE202408202727 over 15 years ago
    The trick is to make the form blocking. Use a global variable to record the result. Try this: defun( MyYesNo (prompt @key (title "Choose"), (focus "yes")) let((formFile, p, form) defvar(MyYesNo_result) formFile = strcat(getWorkingDir(), "/MyYesNo_temp.form") p = axlDMOpenFile("FORM", formFile "w") fprintf(p, "FILE_TYPE=FORM_DEFN VERSION=2\nFORM\nFIXED\nPORT 30 10\n") fprintf(p, "HEADER \"%s\"\n", title) fprintf(p, "TILE\n") fprintf(p, "TEXT \"%s\"\n TLOC 9 2\nENDTEXT\n", prompt) fprintf(p, "FIELD yes\n FLOC 2 7\n MENUBUTTON \"Yes\" 12 3\nENDFIELD\n") fprintf(p, "FIELD no\n FLOC 16 7\n MENUBUTTON \"No\" 12 3\nENDFIELD\n") fprintf(p, "ENDTILE\nENDFORM\n") axlDMClose(p) form = axlFormCreate(gensym(), formFile, '(E INNER), 'MyYesNo_formAction, nil) axlFormSetActiveField(form, lowerCase(focus)) axlFormDisplay(form) deleteFile(formFile) MyYesNo_result )) defun( MyYesNo_formAction (form) MyYesNo_result = case(form ->curField, ("yes", t), ("no", nil)) axlFormClose(form) axlCancelEnterFun() )
  • DE202408202727
    OK, that's not nice. See the attachment. Dave
    MyYesNo.zip
  • redwire
    redwire over 15 years ago
     We should have an obfuscated SKILL code contest in homage to the C contest.  Unfortunately your submission is not obfuscated enough.
    Any takers? :)
  • stillfish
    Thanks Dave, I got it.
    The form is "blocked" by axlFormDisplay(), I was confused by axlUIWBlock() before.
    And using global variable to return value seems to be the only choice.  :)
