  3. teardrops
  • Views 15234
teardrops
Nagendra55
Nagendra55 over 15 years ago
how to add teardrops to the track.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    In release 16.5 there are both fillets (teardrops in traditional understanding) and tapered wires that basically look like a teardrop, but it is used for going from one trace width to another.
    Both can be found inside Route->Gloss->Parameters in the section named Fillet and tapered trace
     I would recommend that you post PCB related questions in the PCB Design part of the community. This part is dedicated to skill programming.
    Best regards
    Ole
  • fxffxf
    fxffxf over 15 years ago
    You also need at least Allegro PCB Designer (was Performance).
    PCB L and OrCAD do not allow addition of teardrops (fillets).
