  3. Changing script parameters & "Replay" from skil functio...
  • Subscribers 166
  • Views 7077
Changing script parameters & "Replay" from skil function
Kadar
Kadar over 15 years ago
Hi ALL,
1) How can I replay a recorded script   but with different parameters(different pick coordinates for example)?
2) I've defined Funckey for Skill function that replays script(axlShell("replay  C:\\Scripts\\Shape_Connection"), then I've tried the function using the
funckey from COMMAND LINE and got this:
W- Cannot exit current application
E- Form field label not found
E- Command not found: fillin GND
E- No command active
I entered the Skill MODE, typed Skill function name and it replayed the script(the script  creates solid shape with specified net, on specified layer, using 8 pick points)
The question is how can I replay script from inside Skill function being in COMMAND MODE?
Thank You All
Evgeni
  • imbritney
    imbritney over 12 years ago
     Ole, what you're outlining above is exactly what I'm trying to do. I've been looking for the syntax for a while, and now I found it.  THANK YOU for posting this!!!  it works beautifully!  :)
