  3. Changing script parameters & "Replay" from skil functio...
  • Subscribers 166
  • Views 7076
Changing script parameters & "Replay" from skil function
Kadar
Kadar over 15 years ago
Hi ALL,
1) How can I replay a recorded script   but with different parameters(different pick coordinates for example)?
2) I've defined Funckey for Skill function that replays script(axlShell("replay  C:\\Scripts\\Shape_Connection"), then I've tried the function using the
funckey from COMMAND LINE and got this:
W- Cannot exit current application
E- Form field label not found
E- Command not found: fillin GND
E- No command active
I entered the Skill MODE, typed Skill function name and it replayed the script(the script  creates solid shape with specified net, on specified layer, using 8 pick points)
The question is how can I replay script from inside Skill function being in COMMAND MODE?
Thank You All
Evgeni
  • DE202408202727
    DE202408202727 over 15 years ago
    Scripts are a messy way of achieving programming results but, if you really have to, embedding the call into Skill does work. To call a Skill file from the command line (or a menu) you need to register a command and put it into your allegro.ilinit file. eg axlCmdRegister("shape connection" 'Shape_connection) Shape_connection.autoload = "Shape_connection.il" Dave
  • Kadar
    Hi Dave, thank you for quick response,
    The reason I want to use script is creation of funckeys for some cases that i have problem
    To achieve the desired result by SKILL. For examle, I want toggle between  "Snap pick to" options (Segment Vertex, Segment Midpoint.........)
    While creation the polygon using "T" button.
    There some commands like "bubset" - used to toggle between slide modes,  that are not mentioned in SKILL reference
    Nor in ALLEGRO commands list.
    Can You please advise me any way to create effective funckeys for toggling Pop-up menu options?
    Evgeni
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    Creating shortcuts for e.g. the snapping functionality is rather simple. If in doubt about the syntax, then record a script while doing a command and then separate the commands by semicolon. Or you could write scriptmode +e in the command line and observe all commands being written to the command window.
    E.g. the snapping you could use the following funckey definitions (won't work if you have s assigned as a single key shortcut)
    When you press s the first time, the PCB Editor will wait for your next key (and in some cases also the 3rd key)
     # s+c for snap to arc or circle center
    funckey sc "prepopup;pop dyn_option_select 'Snap pick to@:@Arc/Circle Center'"
    # s+f for snap to arc or circle center
    funckey sf "prepopup;pop dyn_option_select 'Snap pick to@:@Figure'"
    # s+i for snap to intersection
    funckey si "prepopup;pop dyn_option_select 'Snap pick to@:@Intersection'"
    # s+l to activate slide command
    funckey sl slide
    # s+p for snap to pin
    funckey sp "prepopup;pop dyn_option_select 'Snap pick to@:@Pin'"
    # s+v for snap to via
    funckey sv "prepopup;pop dyn_option_select 'Snap pick to@:@Via'"
    #s+s+m for snap to segment midpoint
    funckey ssm "prepopup;pop dyn_option_select 'Snap pick to@:@Segment Midpoint'"
    #s+s+o for snap to symbol origin
    funckey sso "prepopup;pop dyn_option_select 'Snap pick to@:@Symbol Origin'"
    #s+s+v for snap to segment vertex
    funckey ssv "prepopup;pop dyn_option_select 'Snap pick to@:@Segment Vertex'"
    I hope you can use that? Basically I've been able to create shortcuts for just about anything, so if you have an example, let us know and who knows what will happen.
    Best regards
    Ole
  • Kadar
    Hi Ole,
    This is not exact thing I want to do.
    I want to create funckey(one button only) to get rotating(toggling) mode switching.
    Ctrl+S ---> enterinng Skill function, inside Skill function
    I used inside a loop: EVENT_MASK=list('PICK 'DBLPICK)
     EVEN=axlEnterEvent(EVENT_MASK   OPTION   nil)
    to toggle(only printing to user) between:Pin,Via, Segment Vertex,.......  when EVENT->type=='PICK
    And when EVENT->type=='DBLPICK - breaking loop and executing ... "prepopup;pop dyn_option_select 'Snap pick to@:@Pin'"
    Where "Pin" last printed OPTION to user.
    But it's not so smooth, becase I never get  EVENT->type=='DBLPICK, because the 'PICK  always comes before 'DBLPICK.
    If You understood my question maybe You would generate some idea.
     Thank YOU,
    Evgeni
  • Ejlersen
    Hi
    I don't know how you can accomplish this, sorry.
    Ole
