  3. how to retain variable during skill session
  • Subscribers 159
  • Views 14822
Ejlersen
Ejlersen over 14 years ago
Hi
I've got a skill program that parses data to a new .dra file.
So the program actually saves the current session then start a new dra file and after it is finished with the dra file it reloads the original session.
I'm however experiencing that variables get lost so when I return to the original session. Is there any way to prevent this from happening.
At the same time I would like to clear the memory for all variables when the program terminates.
Best regards
Ole
  • eDave
    eDave over 14 years ago
    Hi Ole, How are you closing and opening each session? I jump between designs in several utilities and don't lose the variables. Of course you will lose the dbid values. Cheers, Dave
  • Ejlersen
    Hi Dave
    Somone (maybe you) once posted the defun AFn_OpenDesign (code further down) which I use together with the following code
    currentDesign = axlCurrentDesign()
    state = axlSaveEnable()
    if(upperCase(axlDesignType(nil)) == "LAYOUT" then
      tempDesignName = "ns_temp.brd"
      if(isFile("ns_temp.brd") then deleteFile("ns_temp.brd"))
    else
      tempDesignName = "ns_temp.dra"
      if(isFile("ns_temp.dra") then deleteFile("ns_temp.dra"))
    axlSaveDesign(?design tempDesignName, ?mode "nocheck", ?noMru t)
    AFn_OpenDesign(?design strcat(draName, ".dra"), ?mode "wf", ?noMru t, ?noConfirm t, ?forceNew t)
    axlSetSymbolType("shape")
    axlDBChangeDesignUnits("millimeters" 3)
    Some code to generate .dra file
    axlDBChangeDesignExtents(extents)
    axlSaveDesign(?noMru t)
    AFn_OpenDesign(?design tempDesignName, ?mode "wf", ?noMru t, ?noConfirm t)
    axlRenameDesign(currentDesign)
    deleteFile(tempDesignName)
    axlSaveEnable(state)
    defun( AFn_OpenDesign (@key design, (mode "w"), noMru, noConfirm, forceNew)
     let((noconfirmStatus, result)
      when(noConfirm, noconfirmStatus = axlGetVariable("NOCONFIRM"), axlSetVariable("NOCONFIRM", t))
      when(forceNew && isFile(design), deleteFile(design))
      result = if(noMru && axlVersion('version) >= 16.0
       then axlOpenDesign(?design design, ?mode mode, ?noMru t)
       else axlOpenDesign(?design design, ?mode mode)
      when(noConfirm, if(noconfirmStatus then axlSetVariable("NOCONFIRM", t) else axlUnsetVariable("NOCONFIRM")))
      result
    Best regards
    Ole
  • Ejlersen
    Hi Dave
    Debugging actually shows when it happens.
    Variable is fine before calling AFn_OpenDesign defun in previous message.
    I can actually pin point it down to the command
    After the defun call the variable is nil, so it happens during the call of that defun.
    Best regards
    Ole
  • Ejlersen
    Hi
    I keep getting wiser. saving the variable into another temp_var = nextline and then reassigning after this line works.
    So it does not clear all variables, but apparently the variable named nextline.
    Does it matter whether a variable is put into a let statement or not? Currently my variables are not for test purposes.
    Best regards
    Ole
  • eDave
    Hi Ole, Yes, it very much matters whether a variable is inside a let statement. Variables inside a let statement will be undefined outside it. I prefer not to let any of my variables "leak" outside a function. If I want a variable to be global I use the defvar statement and identify the variable with a prefix that highlights it. I use the sklint utility to verify my code. Regards, Dave
