  3. after register command, cannot move the component
  • Views 14819
cm123
cm123 over 15 years ago
Hi ,
I have the following code and put to directory  C:\Cadence\SPB_16.3\share\local\pcb\skill. firstly, I click move menu and select a component and type in  command line "move_xy".
Command > move_xy
last pick:  3197.2  7315.5
Command>
But the selected component did not move and go back to original place.
before register command, I put my code in C:/drive and manually load in skill .
skill>load("c:/move.il")
and click move menu and select component and type function name.
skill>move_location
In there, component can be moved to desired location.
Let me know your comments. In command prompt, why the command did not move the component (it means not affect to selected component). I can only see last pick ...... in command prompt.
axlCmdRegister( "move_xy" 'move_location)
procedure( move_location()
let((xy a b cmd_str)
a= 3197.2
 b=7315.5
cmd_str=sprintf(nil "x %.1f %.1f",a b)
axlShell(cmd_str)
axlShell("done")
  • cm123
    I want to share my solution.
    I changed like that.
    a= 3197.2
     b=7315.5
    cmd_str=sprintf(nil "alias tt x %.1f %.1f",a b)
    axlShell(cmd_str)
    axlShell("done")
    after that, in the command prompt, run "move_xy" .
    and in the menu bar, select move menu and select the element I want to move.
    and then in the command prompt, type tt
    it is working.
