  3. how to add function in menu
  • Views 15614
cm123
cm123 over 15 years ago
I want to add my function in menu and my code is the following:
axlCmdRegister("mymenu" 'my_menu)
procedure(my_menu()
let((q z)
q=axlUIMenuFind(nil -1)
z=axlUIMenuInsert(q 'popup "My Menu")
z=axlUIMenuInsert(nil "menu1" "menu_one")
z=axlUIMenuInsert(nil "menu2" "menu_two")
z=axlUIMenuInsert(nil "menu3" "menu_three")
But I need to run command "mymenu" when the PCB editor starts. How can I get automatically my menu when PCB editor starts.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    Take a look at axlTrigger
    Best regards
    Ole
  • fxffxf
    fxffxf over 15 years ago
    The easiest way to add a simple menu is via axlUIMenuRegister. The doc for this command references an example skill file, it looks like you copied the code from the example but you are using the Trigger portion of the example. Use the example code at the end of this file in the menuTrig1 function. More complicated menu additions may require an axlTigger use model but I would 1st try  axlUIMenuRegister.
