  3. Opening new Allegro instance after selecting symbol to ...
  • Views 14789
Opening new Allegro instance after selecting symbol to open
WilliamR
WilliamR over 15 years ago
So the end goal here is to run a cmd click on a symbol and open a new Allegro session with the symbol selected opened up. This is so I can edit a symbol quickly without having to close the board file I have open. The problem I have is grabbing the Symbol name after selection, symbolvar isn't giving me the symbol name. My code so far is:
axlCmdRegister("le" `lib_edit)
defun( lib_edit ()
let((symbolvar fullpath)
axlClearSelSet()
axlSetFindFilter(?enabled '("NOALL", "SYMBOLS"), ?onButtons '("SYMBOLS"))
axlSelect(?prompt "Select Symbol to edit in library")
symbolvar = axlGetSelSet()
fullpath = "run -b allegro $PSMPATH/" symbolvar ".dra"
axlShell(fullpath)
axlClearSelSet()
axlFinishEnterFun()
Any help would be greatly appreciated.
  • djhutchi
    djhutchi over 15 years ago
    As a quick test try changing the 2 lines:
    To:
    symbolvar = car(axlGetSelSet())
    fullpath = strcat("run -b allegro $PSMPATH/" symbolvar->name ".dra")
  • WilliamR
    Wow thanks for the quick reply, that worked great!!!!
