  3. optional command argument
  • Views 16305
Ejlersen
Ejlersen over 15 years ago
Hi
For defun and procedure it is possible to define optional arguments
e.g., defun mycommand ( @optional (nogui nil))
Inside my program I can call the defun with or without the argument as
mycommand or mycommand(t)
however, I would like to be able to use this inside PCB Editor to execute the program with an optional argument, how is that accomplished. I do not seem to be able to find anything in the documentation for axlCmdRegister on this topic.
The command prompt keeps saying command not found mycommand(t)
Any suggestions?
Best regards
Ole
  • fxffxf
    fxffxf over 15 years ago
     on the allegro cmd line just do (without the parens):
           mycommand t
    Notes:
      - Input data is always passed as a string.
      - you might want to use the @rest method since the Allegro cmd line divides up arguments based on whitespace. Skill will throw an error if the user does: mycommand foo bar
  • Ejlersen
    Hi
    Yes, offcourse that was the problem. just got to used to using the skill development window and did the same in PCB Editor :-)
    Thanks for the suggestion for @rest, I can see that I get an error if I type more than one argument but I suppose the same will be true for both rest and optional?
    Best regards
    Ole
