  3. is string a number or not
  • Views 16421
Ejlersen
Ejlersen over 15 years ago
Hi
I've been searching for a funtion to check if a string is a number or not.
stringsamples could be
data="8FLASH"
data="8"
data="8.1"
atoi will return 8 for all of the above, atof will return 8.0 for them all
Anyone know a function to test this?
Best regards
Ole
  • djhutchi
    djhutchi over 15 years ago
    > procedure( test(arg) if(rexMatchp("^[0-9]*[.]*[0-9]+$" arg) then printf("%s is a number\n" arg) else printf("%s is not a number\n" arg)))
    function test redefined
    test
    > test( "0.2")
    0.2 is a number
    t
    > test("2.0")
    2.0 is a number
    t
    > test( "8")
    8 is a number
    t
    > test("8FLASH")
    8FLASH is not a number
    t
  • DE202408202727
    DE202408202727 over 15 years ago
    Hi Ole, There must be a better way but this might help you: defun( StrNumberType (str, "t") when(str != "-" && substring(str, 1, 1) == "-", str = substring(str, 2)) unless(forall(pattern, '("^[0-9]+$", "^[0-9]*.[0-9]+$", "^[0-9]+.[0-9]+e[0-9]+$", "^[0-9]+.[0-9]+e-[0-9]+$"), !rexMatchp(pattern, str)) type(readstring(str)) ) ) Regards, Dave
  • DE202408202727
    Let's try that in ie instead of Chrome:
  • Ejlersen
    Hi Dave
    Looks much better and thanks very much for the answer, although it was down the same road I was looking.
    There's also numberp, but converting a single element string to a symbol does not seem to work well.
    Best regards
    Ole
