  3. Deleting Functionpin
  • Views 13609
vramananx
vramananx over 14 years ago
Hi
I want to delete the "pin name" from a pin
it is under functionPins on a component definition, if you query a pin then it will be listed as "pin name"
basically i want to rip out all the logical information on a selected region, clines/shapes/net etc
I am using axlDeleteObject witthout Equivlogic so i can remove the net and all the other stuff without any issue
(p.s. i can also use axlRemoveNet to delete the nets)
but still the pin name sticks around
I would appreciate if anyone can show me if there is a way to remove the pin name or make it nil
regards
Venkata
