  3. someone do the HDL check plus code? help check this issue...
  • Views 13765
someone do the HDL check plus code? help check this issue, please!
pcbskill
pcbskill over 14 years ago
How to understand the bodypin? and what's the relationship between the bodypin and the body?
some one can give me a hands about it?
// the code for check if the bodypin has the  BIDIRECTIONAL property.
Rule nv_graphical_Bodypin_inout                        // can not found correctly even the pin has been define as a BIDIRECTIONAL='TRUE' in prt file.
    pin2 := foreach( pin1,
      bodypin1 := bodypin( pin1 ) AND
      inout( bodypin1 ) AND
      sName1 := concat_str( name(bodypin1) + "has the BIDIRECTIONAL property\n" ) AND
      append( linorout, sName1 )
    ) AND
    sName2 := name(pin2)
    Message(info, pin2, "?sName2", "\nGot the Pin which has the BIDIRECTIONAL property:\n\t?linorout");
  EndRule
