  3. Edit a Text File and Replace a string
  • Views 15358
vramananx
vramananx over 14 years ago
Hi
I want to open a text file and replace a particular pattern with another
I know i can use the regex to do the search and replace
i also know how to open the file
the thing i am not able to figure out is, how to read the entire text file
I am thinking I can read one line at a time and do regex for each line, then I can write the result to a new file
I need help in how to do this
 here is what I want to do
in = inport("file.txt")
lineread one line at a time assign to a string
use regex replace
fprintf the result to a new file
I also appreciate if anyone can suggest a better method
regards
Venkata
  • SkilSiao
    SkilSiao over 14 years ago
    Hi Venkata, if i interprete correctly, you want to do a "read" of the entire text file first
    then followed by a "replace"?
    you may store each line of the input (from the file, as string)
    to a temp_list first, then compile the rex (or others required by your function),
    and then make a foreach loop to do the replacement.
