  3. Require skill script/function for silk screen coordiant...
  • Views 5380
Require skill script/function for silk screen coordiantes
KetCadence
KetCadence over 14 years ago
I am trying to find skill function or develop a skill script that would provide me co-ordinates
of silk screen of a component. I was not able to find such function.
Could anyone please help me with this?
Thanks.
  • DE202408202727
    DE202408202727 over 14 years ago
    Look at the children of the symbol that are using the silkscreen layer. eg: component = axlDBFindByName('refdes "IC1") silkscreenObjects = setof(dbid, component ->symbol ->children, dbid ->layer == "PACKAGE GEOMETRY/SILKSCREEN_TOP") Dave
  • KetCadence
    Dave, Thanks for your reply.
    Your method worked for getting the silkscreen coordinates for components.
    Now, I was trying to get coordinates for "BOARD GEOMETRY/SILKSCREEN_TOP".
    I tried using "axlLayerGet(layerName)" and it gave me param dbid of layer.
    However, I was not able to extract any co-ordinate or shape related properties from it.
    I also tried, getting shapes on "BOARD GEOMETRY/SILKSCREEN_TOP" layer
    using:
    shapeList = axlDBGetShapes("PACKAGE GEOMETRY/SILKSCREEN_TOP");
    It is returning  null list.
    Does anybody have worked on this previously and have any idea how to get this information?
    Thanks.
  • DE202408202727
    1/ Layers don't have any shape-related properties.
    2/ axlDBGetShapes will only return shapes. Chances are that you don't have any shapes on that layer - just lines and text.
  • KetCadence
    Hello Dave,
    As you suggested, there are no shape properties involved with "BOARD GEOMETRY/ SILKSCREN_TOP".
    I guess there should be some lines, clines associated with it.
    So, I was trying to get hold of those line objects in order to get required extents of silkscreen.
    I came acorss an utility developed by you called autoSilkUtils_public.il
    One of the change log in header information suggests:
    "8.20    26-Aug-09 DE    Also select associated objects that do not have a parent - such as board geometry text."
    So I was searching for the function related to above mentioned functionality.
    I found function called "findTypeObjects (types @key visibleOnly, layers, attrPairs, props, bbox, point, xy)".
    If I am correct, it is related to functionality related to above change log.
    I tried to use it as follows:
    objs = findTypeObjects("LINES", ?layers "BOARD GEOMETRY/SILKSCREEN_TOP")
    It gave me one dbid, but I am not able to identify what it is exaclty.
    I tried to print "objs->??", and it is nil.
    Could you please let me know, if this functionality could be used to get hold of line objects
    present in BOARD GEOMETRY/SILKSCREEN_TOP ?
    I am trying to debug this thing, but since I am new to this kind of scripting it is difficult to understand.
    Thanks.
  • DE202408202727
    Yes, you are on the right track. findTypeObjects returns a list. car(objs) ->?? will return something.
