  3. Opening files from Allegro
  • Views 16007
emldebh
emldebh over 14 years ago
I have a Component definition property called datasheet location that describes the path to a pdf file. I want to be able to open this in Allegro dependent on which component I select. Can anyone tell me if this is technically possible.
Dave
  • DE202408202727
    DE202408202727 over 14 years ago
    Hi Dave,
    Yes, it is possible - even easy!
    See attached. You will need to edit some lines and using a registered interactive command to run the file will work best.
    Dave
    Public_ShowCompDataSheets.zip
  • emldebh
    Thanks Dave,
    I'll give it a go
    R
    Dave
  • emldebh
    Just realised that the property is coming through as an instance property not a comp def. So it won't pick it up
  • emldebh
    Got it working now. Changed the Allegro.cfg file to send the property through as a Compdef and it works superbly. Thanks for the tip
    R
    Dave
