  3. axlShell() and select function
  • Views 15726
Klaudia
Klaudia over 14 years ago
Hi. Nice to meet you.
I want to exec 'done' before select symbols. so I make skill procedure like this
procedure(selectsymbol(symboldbid)
    axlShell("done")
    axlSingleSelectObject(symboldbid)
During test, I does not found problem this procedure. because the test is running by a single line
But, if you run 'selectsymbol' procedure, you will be able to see deselected symbol after selected
It looks like axlShell problem.
Do you have a good ida? to solve this problem.
  • GIL2004XP
    GIL2004XP over 14 years ago
    Hi Klaudia,not sure about the function of your axlshell("done") if this will just finish your previous command, have you tried using axlFinishEnterFun() instead?
