  3. axlAirGap help
  • Subscribers 163
  • Views 14517
axlAirGap help
pcbnagaraj
pcbnagaraj over 14 years ago
Dear All,
I am trying to find the air gap between a shape in PACKAGE GEOMETRY/SILKSCREEN_TOP layer  and via using VIA CLASS/SOLDER MASK TOP
axlSetFindFilter(?enabled list("noall" "pins" "vias" "clines" "shapes" "lines" ) ?onButtons list("noall" "pins" "vias" "clines" "shapes" "lines"))
axlSingleSelectBox(bbox) ; this selects both shape and via with bbox as user input
select_list = axlGetSelSet()
silk_shape_dbid = car(select_list)
via_dbid = cadr(select_list)
axlAirGap(silk_shape_dbid  via_dbid  "VIA CLASS/SOLDERMASK_TOP" t )
running this I get error
W- *WARNING* ilMakeString: NULL String, changed to "".
(NOMATCH
Please help. What am I doing wrong ?
Nagaraj
  • fxffxf
    fxffxf over 14 years ago
    You have two issues:
    •   the 2 objects don't share the same layer so you need to use a different option for the 4th arg
    •   you may have pins in your list so "VIA CLASS" would be wrong for them
    use: axlAirGap(silk_shape_dbid  via_dbid  "VIA CLASS/SOLDERMASK_TOP" 'anyLayer )
    •    if the  via_dbid is a PIN substiture "PIN" for class name
    If you use 'enhanced for the 4th arg then the return reports the layers used for measurement.
  • pcbnagaraj
    It worked!!
    Thanks.
    Appreciate if this could be documented.
    Nagaraj.
