  3. Export Manufacturing Files
  • Views 16088
Nancie
Nancie over 14 years ago
Hi All !
 I'm a beginner in skill. Sorry for my English too! I'm not Bilingual :)
I want to create a skill for exporting the manufacturing files in 1 click.
Gerbers - Drill file - ROU file - Placement File.
First of all, I need to know how to acces to the menu in allegro.
I try to find something in skill for open the menu : Manufacture -- Artwork.
I found one that doesn't work well :   axlFormTest("artwork")
It open half of the originale form, and I can't click in it.
I know it's only for test this one, but do a function exist for open ? axlFormOpen?
Best regards
Nancie
  • DE202408202727
    DE202408202727 over 14 years ago
    Hi Nancie,
    No doubt many people try to do this and there are many Skill solutions out there.
    However, Have you looked at ODB++? This is an elegant solution that doesn't require Skill coding. It is rare to find a fabricator that won't accept ODB++ these days.
    If you continue down the Skill path I suggest you start with something more simple to learn with. At this point you won't need access to the  menus. You can write Skill that you can run from the command line and add it to the menu later. You will need to create your own Skill form. Look at some of the examples in ...\share\pcb\examples\skill\form
    Good luck,
    Dave
  • RA202501192230
    RA202501192230 over 1 year ago in reply to DE202408202727
    Hi Dave,
    If you are having any skill .il file for full output generation
  • DE202408202727
    DE202408202727 over 1 year ago in reply to RA202501192230
    Hi Nanciehttps://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/DE_5F00_gerbers_5F00_out.zip
    Try this for exporting Gerbers.
    Dave
