  3. build a popup of "Temp Group"
  • Replies 7
  • Views 7103
SkilSiao
SkilSiao over 14 years ago
Hi all, I want to make an item of "Temp Group" in Right-click popup (which is same as "copy" "move" command)
so that user can make continuous selection.
my function look like this:
mypopup = axlUIPopupDefine(nil '(
    ("Done" "axlDBTransactionCommit(mark), axlFinishEnterFun()")
    ("Oops" "axlDBTransactionOops(mark), when(zerop(--oopsNum), printf(\"Nothing Selected!\\n\")")
    ("Cancel" "axlDBTransactionRollback(mark), axlCancelEnterFun()")
    ("MENU_SEPARATOR", nil)
 ("Temp Group" "axlUIPopupSet(mypopup1) ... "))) ; end define the popup
 axlUICmdPopupSet(mypopup)
 mypopup1 =  axlUIPopupDefine(nil '(
 ("Complete" " ... "))) ; end define the popup
 axlSetFindFilter(?enabled ... ?onButtons ...)
 while( axlSelect(?prompt sprintf(nil "Select object(s) to continue.\n"))
temp_list = axlGetSelSet()
caseq(length(temp_list)  (0 ...) (1 ...) (t ...)
) ; end caseq
) ; end while
I have been thinking of how to write function for the "Temp Group" and "Complete" so that the selection done by user
can be stored in temp_list, because in the while loop, the temp_list = axlGetSelSet() to allow a single selection.
 anyone can help. thanks in advance.
  • Silver John
    Silver John over 14 years ago
    I have not tested this code, now I haven't ability for this.
    This is a direct, linear solution, and can not be the best.
    done = nil
    selected_obj = nil ; JIC
    one_point = nil ; JIC
    mark = axlDBTransactionStart()
    while( done == nil
        axlSelect(?prompt "Select object(s) to continue.") ; waiting user pick
        selected_obj = axlGetSelSet()
        if(selected_obj then
            one_point = axlEnterPoint(?prompts "Select a point.") ; waiting user pick
        if( (selected_obj && one_point) then
            axlDBTransactionMark(mark)
            printf("DO IT")
            selected_obj = nil
            one_point = nil
    );end while
    defun( myOops ()
        axlFinishEnterFun() ; exit from wating operations
        axlDBTransactionOops(_alnTransactionMark)
    );end-fun
    defun( myDone ()
        axlDBTransactionCommit( _alnTransactionMark )
        done = t
    );end-fun
  • SkilSiao
    Hi Silver, yes. I got it. your function has given me a very good example
    for further development (and things can be achieved with some additional controlling
    parameters to the if else within the while loop). Thank you very much. =).
    Actually i am looking for a 2-stage selection with the 2nd stage repeating (like "Copy"),
    i have been thinking of a while loop like :
    while ( .. ... ... axlDBTransactionMark(mark) ... axlDBTransactionMark(mark) ... )
    which comes with multiple DB Transaction marking within a while loop,
    but i found it not possible.
    Thanks again for the help, it really helps me with a breakthrough in writing
    user interface functions.
