  3. build a popup of "Temp Group"
  • Replies 7
  • Views 7102
SkilSiao
SkilSiao over 14 years ago
Hi all, I want to make an item of "Temp Group" in Right-click popup (which is same as "copy" "move" command)
so that user can make continuous selection.
my function look like this:
mypopup = axlUIPopupDefine(nil '(
    ("Done" "axlDBTransactionCommit(mark), axlFinishEnterFun()")
    ("Oops" "axlDBTransactionOops(mark), when(zerop(--oopsNum), printf(\"Nothing Selected!\\n\")")
    ("Cancel" "axlDBTransactionRollback(mark), axlCancelEnterFun()")
    ("MENU_SEPARATOR", nil)
 ("Temp Group" "axlUIPopupSet(mypopup1) ... "))) ; end define the popup
 axlUICmdPopupSet(mypopup)
 mypopup1 =  axlUIPopupDefine(nil '(
 ("Complete" " ... "))) ; end define the popup
 axlSetFindFilter(?enabled ... ?onButtons ...)
 while( axlSelect(?prompt sprintf(nil "Select object(s) to continue.\n"))
temp_list = axlGetSelSet()
caseq(length(temp_list)  (0 ...) (1 ...) (t ...)
) ; end caseq
) ; end while
I have been thinking of how to write function for the "Temp Group" and "Complete" so that the selection done by user
can be stored in temp_list, because in the while loop, the temp_list = axlGetSelSet() to allow a single selection.
 anyone can help. thanks in advance.
  • Silver John
    Silver John over 14 years ago
     I do not quite understand your starting position, and ultimate goal.
    Look at how I done a similar functionality (pay attention: used standard TempGroup, "from box"). Maybe this will help you.
    In my program, you can select one or more objects, you can use a temporary group.
    Align Tool
    See "popupA", "_alnSelectedObjects" and main loop "while( _alnFinish == nil ... )"
  • SkilSiao
    Hi Silver, thanks for the suggestion. i am going through the code... actually my problem is like this: I want to write a two-stage prompting selection by user... Just like "copy" command, first prompt user to select object(s), then followed by prompting user for a point of copy origin (User Pick), and Oops is available during the command for user to reselect object(s) or origin. my coding looks something like this, (i skip certain portion as it will be too long to read...) the Oops/ Cancel/ Done popup are standard, linking to DBTransactionOops/ RollBack/ Commit. mark = axlDBTransactionStart() not_done = t while( not_done axlSelect(?prompt "Select object(s) to continue.") axlDBTransactionMark(mark) selected_obj = axlGetSelSet() axlClearSelSet() axlHighlightObject(selected_obj nil) one_point = axlEnterPoint(?prompts "Select a point.") printf("the point selected is %L.\n" one_point) );end while The problem is, after selecting the objects (1st stage), if Right click->Oops is entered, the while loop will continue to 2nd stage (select a Point). even I add in another TransactionMark after the axlEnterPoint. Is there a way to achieve the two select prompting with the Oops? Thanks in advance.
  • SkilSiao
    Re-post.
  • Silver John
    Use the special condition (dirty fix, finally).
    This is only a problem of algorithmic and you have to solve it itself.
    For example see the line in my code: "if (_alnHandler then axlFinishEnterFun ()); for exit from 'doPickH or' doPickV".
    In doPickH() function I wait while user pick.
  • SkilSiao
    Hi Silver, Many thanks.
    Yes, it is a two-stage prompt in aln command, From Select Object(s) to Choose Action.
    I find that the doPickH() is called from the callback function (correct me if i am mistaken)  and not
    initiated from the while loop which resides in the main function. It is a good idea as it does offer
    another approach (from form button) to capture users' one-by-one input.
    refer to the following coding (Sorry abt my previous posts as i was with google Chrome), i want to
    prompt user for two inputs, first is object and the second is a point :
     not_done = t
    axlDBTransactionMark(mark)  axlClearSelSet()
    );end while
    I am wondering whether it is possible to "oops" from the "Select a point" back to "Select
    object(s)". Everytime when I "oops" (axlDBTransactionOops)  it will just continue the while loop
    (select a point) instead of going back to top...
