  3. The offset when operate the cirular polygon
  • Replies 12
  • Views 20591
YangJinxiao
YangJinxiao over 14 years ago
There is a circular shape, which has a circular void, I want to use 1 mil width of the line to cur the void, making the circular shape has no void. Process: the polygon of shape = poly1; the polygon of void = poly2; the polygon of cut line = poly3; Use axlAirGap get the minimum distance between the circular void and the outline border of circular shape. according to the endpoints of axlAirGap result, create the 1 mil width cut line. get the polygon of the cut line (that is, poly3); result = axlPolyOperation(poly1 poly3 'OR); Issue: The graphical result of the combined position is offset. And the original shape is not completely overlap. How should I solve this offset problem? How can i get the right result. Thank you!
  • YangJinxiao
    Hi Dave:
    I can see that ,improve the design accuracy can reduce the offset.
    But in the process of layout, improve design accuracy will take a lot of time,
    and then reduced to the original setting of the board will not only take a lot of time and may cause some DRC error.
    We can find that: the axlPolyOperation function use the design accuracy in the calculation.
    Why not use the max accuracy in the calculation to reduce the offset??
    Are there other ways to solve the offset?
    Allen
  • DE202408202727
    DE202408202727 over 14 years ago
    If you run the Skill utility with more design accuracy it gives better results. When you have the shapes in your design and bring the accuracy back to 1, you will see that the offset reoccurs. To my mind this is a mathematical necessity. Arcs created this way are never going to be well represented if you choose low accuracy in Allegro.
