  3. How to pass window Location inside axlUIViewFileCreate
  • Subscribers 163
  • Views 15975
pcbnagaraj
pcbnagaraj over 14 years ago
 Dear All,
I am trying to pass location of window inside the  axlUIViewFileCreate.
I am unable to get a reference/example inside the algroskill.pdf and other help documents.
I tried below but no success
  axlUIViewFileCreate("symbol.log" , "Symbol Property", nil ?lt_placement "n")
axlUIViewFileCreate("symbol.log" , "Symbol Property", nil "n")
axlUIViewFileCreate("symbol.log" , "Symbol Property", nil  "north")
 Thanks for your help.
Nagaraj.
  • fxffxf
    fxffxf over 14 years ago
    There are two modes of operation depending upon the view file window type:
    • new style html based window (env variable "set allegro_html" being used). If this msg window is enabled you will see a push pin in the upper left corne.
    • old style text window
    HTML STYLE:
    • Option is currently ignored
    • System remembers user position on subsequent invocations.
    OL D STYLE:
    • The default placement is relative to the Allegro window NOT the desktop. A suggestion of "north" is to position the window within the Allegro main window at the top middle. This is a suggestion; if it can't place the window at that location (such as it will be outside the desktop) then it will do its best.
    • If this was a form (e.g. axlFormCreate), this only applies the 1st time. The system remembers and saves (<HOME>/pcbenv/allegro.geo), the user's desired positioning of the form window.
    If you want to place the window outside of the allegro window then you need to use "outer". The argument expects a list of placement suggestions.
    position = '("outer" "east")  ; try to position the window to the right of the Allegro window
    axlUIViewFileCreate("symbol.log" "Symbol Property", nil position)
  • pcbnagaraj
    Hello Frank,
    I tried but results in below warning message and no change in window placement. My interest is to place window within Allegro GUI.
    I have two reports to display to user but both get displayed one above the other.
    I need to know how to pass the Window placement(page 459 of algroskill.pdf under user interface functions->window placement) arguments inside axlUIViewFileCreate.
    Skill > position = '("outer" "east")
    ("outer" "east")
    Skill > axlUIViewFileCreate("symbol.log" "Symbol Property", nil position)
    W- *WARNING* (axlViewFileCreate): Invalid integer - "outer"
    windowMsg:97394056
    Appreciate your help.
    Nagaraj.
  • fxffxf
    mistype, try: axlUIViewFileCreate("symbol.log" "Symbol Property", nil nil position)
  • pcbnagaraj
    Now no errors, but both the windows still popup one over the other in the same location. I have the “Enable HTML” variable set.
    position = '("outer" "west")
    axlUIViewFileCreate("pin.log" "pin Property", nil nil position)
    TIA,
    Nagaraj.
  • fxffxf
     With the HTML style the positioning option iscurrently not supported.
