  3. Create Route Keep Out Using Screw Hole and NPTH...
  • Views 15677
eDaNoy
eDaNoy over 14 years ago
 Hello everyone, i am developing a module that will create RKO on inner layer
for Screw Hole and NPTH Hole...
I used axlPolyFromDB, and i targeted symbol pin as target,
although i made it work already, i am not satisfied by its speed and credibility
I have to search through its deepest property,
here is my code, pls help me to make it short and to enhanced its speed and credibility
            (unless shapeDbid
                myComp=axlDBGetDesign()->symbols
                (when myComp
                    (foreach pinSelected myComp
                         (when pinSelected->name==itemName
                            symbolPins=pinSelected->pins
                            (when symbolPins
                                (foreach symPinSelected symbolPins
                                padCntr=0
                                    selectedPin=symPinSelected->pads
                                    (foreach _xx selectedPin
                                         (unless pinSelected->component
                                             (unless pinSelected->net->name
                                                (when _xx->objType=="pad"
                                                    (when _xx->type == "REGULAR"
                                                        (when _xx->layer == "PIN/SOLDERMASK_TOP" || _xx->layer == "PIN/SOLDERMASK_BOTTOM"
                                                            ++padCntr
                                                            (unless padCntr>1 ;avoid repeatation
        polyList = car(axlPolyFromDB(car(_xx->figure), ?layer itemLayer ?padType 'REGULAR))
        polyList = car(axlPolyExpand(polyList 20 "NONE"))
        shapeCreatedDBid=axlDBCreateShape(polyList t itemLayer)
        (when listp(shapeCreatedDBid)
        shapeCreatedDBid=car(shapeCreatedDBid)
        axlDBCreatePropDictEntry("FR_SKILL_HOLECHECK" "string" , list("shapes"))
        axlDBAddProp(shapeCreatedDBid list("FR_SKILL_HOLECHECK" itemName))
        axlDBAddProp(shapeCreatedDBid list("FIXED" t))
        printf("%s for %s  created.\n" itemLayer itemName)
as you noticed i used "padCntr" to avoid repeatation, because each pins could find attributes with thesame type, pad, layer and objType
  • DE202408202727
    DE202408202727 over 14 years ago
    (unless shapeDbid
    (foreach mechSymbol setof(sym, axlDBGetDesign()->symbols, sym ->name == itemName && !sym ->component)
    (foreach mechPin setof(pin, mechSymbol ->pins, !pin ->net)
    pad  = car(setof(p, mechPin ->pads, pad ->type == "REGULAR" && (p ->layer == "PIN/SOLDERMASK_TOP" || p ->layer == "PIN/SOLDERMASK_BOTTOM")))
    when(pad
    polyList = car(axlPolyFromDB(car(pad ->figure), ?layer itemLayer ?padType 'REGULAR))
    shapeCreatedDBid = car(axlDBCreateShape(polyList t itemLayer))
    (when shapeCreatedDBid
    ); when shapeCreatedDBid
    ); when pad
    ); foreach mechPin
    ); foreach mechSymbol
    ); unless
  • eDaNoy
     thanks Dave, im will try to incorporate it today on my module
