  3. Run .scr from Skill
  • Views 16664
Run .scr from Skill
Brian Collins
Brian Collins over 14 years ago
 I am trying to compact the existing text blocks, then import a paramter file in a .dra in v16.3 S042. It appears that none of the xml import interfaces are exposed in Skill, so I am trying to run a .scr . I can run each line individually and it works. I can replay the .scr and it works, however, when I run the whole thing from a skill program it returns the following:
W- Cannot exit current application
E- Can't find window; form.parm_in
 I have attached the skill program. Note that I have tried doing the commands in-line and externally, but the result is the same. I have also marked the command as "interactive", but that does not seem to help.
tbcompct.il
  • DE202408202727
    DE202408202727 over 14 years ago
    Your code works for me in 16.5 but... can you not use axlImportXmlDBRecords?
  • Brian Collins
     Dave:
     Yes,  axlImportXmlDBRecords() works in 16.3. As I have 16.5 installed on my system, I was able to look up the call sequence
     Thanks!
    Brian
  • fxffxf
    fxffxf over 14 years ago
    change your axlCmdRegiste from:
         axlCmdRegister( "tbcompct" 'Tb_Compct ?cmdType "interactive" )
    to
        axlCmdRegister( "tbcompct" 'Tb_Compct ?cmdType "general" )
  • Brian Collins
     Thanks! Works like a charm...
