  3. How to get physical constraint rule settings in allegro...
  • Views 14791
How to get physical constraint rule settings in allegro 15.2 or 15.7?
jasonzhou
jasonzhou over 14 years ago
Hi, everyone
I need to get physical constraint settings in skill by axlCNSGetPhysical function. But i found this axl function was not defined in 15.2 and 15.7. Then how can i get physical constraint settings?
Please help me.
Jason
  • Pawandeep
    Pawandeep over 14 years ago
    Hi Jason,
    I am using 16.5 ver so I am not aware of functions in 15 ver.
    There can be an indirect way to read the constraints from TCF file using a program. Techfile should contain all the physical constraint settings. Let us know if this or any other method works.
    File>Export>Techfile
    Pawan
  • jasonzhou
     Hi Pawan,
     Thanks a lot! I think it's a good idea to get constrains from TCF files.
     I'm now trying to read the constraints information from Reports. Use command:  reports "Constrains Report"  to extract constrains details.
     Best regards,
     Jason
