  3. Change_Net_o_Vias.il
  • Views 15549
msalberg
msalberg over 14 years ago
Hi all,
Change_net_on_vias.il is a very useful Skill file!
However, Is it difficult to add the ability to "Pick" a net by clicking on a Pad or Cline in aAllegro?
As it is now, I show element on net to copy netname, then paste this netname in the change net dialog box.
change_net_on_vias.il
  • DE202408202727
    DE202408202727 over 14 years ago
    See attached.
    Place the (unzipped) file: "DE_changeViaNet_public.cxt" in your Skill path
    In your allegro.ilinit file add the following lines:
    loadContext("DE_changeViaNet_public.cxt")
    axlCmdRegister("chgvianet" 'CVN_changeViaNet ?cmdType "interactive")
    Type "chgvianet" in the console window to run the utility. Use the Right Mouse Button for options.
    DE_changeViaNet_public.zip
  • msalberg
    Hello Dave,
    Thank you so much for your reply!
    That really works well! I like the cross hairs scope look while looking for vias.
    So looks like I should run the original one to pick a net list or this one to pick a segment, pin, etc…
    Judging from this, I have both in my menu.
    I was just wondering, it seems to not matter if I pick pin, segment, etc…
    My concern is if it pick the wrong thing…such as a RAT, other segment, etc…
    Thanks once again Dave!
    Mark
  • DE202408202727
    Hi Mark, Test it! It will give you the choice of nets if more than one found at the selected location. Regards, Dave
