  3. undefined function - axlDBNetCreate
  • Subscribers 159
  • Views 2187
rumar
rumar over 13 years ago
hi
I'm pretty new to SKILL, so maybe I just missed something simple. I started a new project in Allegro PCB Designer and can use several axl-functions but not the axlDBNetCreate. I found following example in the help:
net = axlDBNetCreate("net1")
but it returns
E- *Error* eval: undefined function - axlDBNetCreate
Adding a new net manually in the GUI by "Logic->Net Logic" works after I ticked the logic_edit_enabled option in the user preferences.
Anyone having an idea what I'm doing wrong?
Thanks, Marcel
  • Pawandeep
    Pawandeep over 13 years ago
    Some skill functions may not available for use in previous releases like 15 ver. Please refer the installed help files to cross check.
  • rumar
    mmhhh, I'm using release 16.5 with the latest hotfix. So this shouldn't be the problem. How can I check if my release or Allegro version supports this command? In the help files this function is listed.
  • Pawandeep
    Marcel seems like you are the 1st person to use this function :-)
    The syntax for axlDBCreateNet() is wrongly mentioned as axlDBNetCreate()
    I will create service request to Cadence to fix it.
  • rumar
    axlDBCreateNet indeed fixed my problems. Thank you very much!
